Dropbox Sync Issues after updating (1.8.5 -> 2.0.11)
Joplin 2.0.11 (prod, win32)
Client ID: XXXXXXXXXXX
Sync Version: 2
Profile Version: 39
Revision: 981b1d845
Syncing with Dropbox. Running Windows 10. Error persists on Mac OS Big Sur.
Updated from 1.8.5 to 2.0.11. No errors until after update.
I only use Dropbox.
Tried similar steps as per
Major breaking change in coming Joplin Server 2.0
I've tried file menu --> export all as JEX (for back up)
Re-sync local data to sync target.
Joplin re-started.
Let sync continue.
Error still exists.
I've removed Joplin from Dropbox's authorized app list.
Re-added Joplin to Dropbox's authorized app list.
Error still exists.
Here is
log.txt (387.5 KB)
Halp?
The
console error.txt (2.5 KB)
showed the following "error".
iOS app now shows an error on sync.
Are you trying to upload a very big file? The error in your log is 413 - request too large
The video file I’m trying to upload is 185.9mb mov file. I ended up deleting that video, then things got out of sync.
Through console, I found the resourceID of the video (fedcfc47112b43bab816667b09bf3778).
Using the search bar on Joplin with that resourceID yields no notes nor results.
I think I'm dealing with an orphaned resource that's somehow stuck.
I'm also having sync issues. Not using dropbox, but filesystem and macos/android. I've filed a ticket here: synced note from android not displaying in joplin desktop · Issue #5099 · laurent22/joplin · GitHub
Where are you sync-ing it to? Your personal computer?
yeah, macos <-> android. Another difference from you is I'm using a non-dropbox solution to sync so I've selected the filesystem option.
