Hello! Having a bit of an issue with authorization… when following the steps to authenticate and copy-paste the code issued by dropbox, I’m running into the following error message:
I did ensure that the complete code was pasted exactly as-given.
Anything I should check off the bat? Googling the message itself, and searching here, hasn’t turned up much. Thanks.
The Dropbox API sometimes have temporary problems which are fixed later on, so maybe try again in an hour or so? The error seems to indicate that api.dropboxapi.com doesn’t exist which is not possible.
