Ok, that kind of makes sense. I'm new to Joplin plugin authoring. Where can I find all of the icon definitions and names included with Joplin? I'm targeting the desktop app. For instance, in the official repository there is a plugin example here: https://github.com/laurent22/joplin/tree/dev/packages/app-cli/tests/support/plugins/register_command/src
The content I'm interested in:
await joplin.commands.register({
label: 'My Test Command 2',
iconName: 'fas fa-drum',
execute: async () => {
alert('Testing plugin command 2');
Where can I find all values for iconName? This specific command references fas fa-drum. Where is the author getting these icon labels and how do I know which are included in Joplin?
Another plugin called Multi-markdown Table Tools defines buttons in the same way:
label: "Format all tables",
iconName: "fas fa-star-of-life", // fas fa-table-cells, icon-table2
accelerator: null,
add: {
toContextMenu: false,
toToolsMenu: "tableToolsFormat",
asToolbarButton: true
condition: CommandCondition.None,
execute: editorExecCommand("formatAllTables")
Again, how do I know what icons are available? Where is the author getting fas fa-star-of-life?
Does Joplin include all FontAwesome free icons?
Also, I found this page on Plugin Theming.
It says:
On desktop, your plugin view will have access to icons used by the app. It is however not recommended to use them because they may change in future versions. And it will also make your plugin incompatible with the mobile app (which does not expose any icon library).
Instead a recommended approach is to add Font Awesome in your plugin project, and to import only the icons you'll need. To do so using React, follow these instructions:
Install Font Awesome:
npm install --save @fortawesome/fontawesome-svg-core @fortawesome/free-solid-svg-icons @fortawesome/free-regular-svg-icons @fortawesome/react-fontawesome
Import and load the icons:
From one of your top TypeScript files:
import { library } from '@fortawesome/fontawesome-svg-core';
// Import the specific icons you want to use
import { faTimes } from '@fortawesome/free-solid-svg-icons';
import { faCheckCircle } from '@fortawesome/free-regular-svg-icons';
// Add the icons to the library
library.add(faTimes, faCheckCircle);
Should I follow the approach outlined in the "Plugin Theming" document and install @fortawesome/fontawesome-svg-core etc. into my plugin project, or is there an easier way to just pull/define icons that come with Joplin?
