Debian 10 installation not running
I try to run joplin on debian buster with a raspberry pi desktop.
But after the install I receive an error. I could not fix. :frowning_face:
Regarding my system:
cat /proc/version
Linux version 4.19.0-16-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.181-1 (2021-03-19)
I have tried the installation with:
wget https://raw.githubusercontent.com/laurent22/joplin/master/Joplin_install_and_update.sh
If I try to start joplin via the icon. I get an error message :boom::
Failed to execute child process “/home/pi/.joplin/Joplin.AppImage” (No such file or directory)
But the appimage is in the right location and executable :disappointed:
pi@raspberry:~ $ ls -alh /home/pi/.joplin/Joplin.AppImage
-rwxr-xr-x 1 pi pi 141M Jun 16 19:33 /home/pi/.joplin/Joplin.AppImage
If I run the installation command twice i read in the output
The latest version is 2.0.11, but you have no version installed.
I am obviously not a expert on linux and do not know how to fix it.:worried:
Thank you in advance for any kind of help.
@wadam welcome to the forum.
If this is the Raspberry Pi Desktop for PC I notice that the ISO is named:
2021-01-11-raspios-buster-i386.iso
So I am wondering if they may be using a 64-bit kernel (hence the cat /proc/version output) but on a 32-bit system? (ie using a 32-bit system similar to that used by RasPiOS on ARM). I believe that the AppImage does not run on 32-bit.
Just a guess :slight_smile:
Hello
my
kernel should be 64 bit
cat /proc/version
So I guess the topic with 32 bit and the appimage should not be the problem
My point was that the kernel may be 64-bit but the system and its libraries may not.
how could it look for that?
I don't know. That's what I am trying to find out at the moment! :slight_smile:
I do not know if:
pi@raspberry:~ $ uname --m
x86_64
does the job?
getconf LONG_BIT shows 32 which I think means that the system itself is actually 32-bit despite the kernel being 64-bit....
Your are right
pi@raspberry:~ $ getconf LONG_BIT
32
Is there an other way to install joplin then the appimage?
There are unofficial versions (such as Flatpak) but I don't think that any of them will overcome the fact that the Raspberry Pi Foundation has built their Debian Desktop OS as 32-bit and Joplin requires 64-bit.
The issue of 32-bit has arisen before and does not appear to have been resolved by anyone who wants to run Joplin on a 32-bit OS.
Assuming you want to keep with this OS a check of the RasPi downloads server shows only rpd_x86 so a 64-bit Raspberry Pi Desktop for PC does not appear to be an option either.
The Joplin AppImage works fine on Linux Mint :slight_smile:
