Hi, it's my contribution for Joplin, it's a Python 3 script working with web clipper API. (Then you need to enable it.) ![]()
After that, just do somes $ python3 script.py
Then the script convert all gnote notes to Joplin, with chronologic order (modification/created)
Of course, Joplin should be started before running this script ![]()
import os
import re
import time
import datetime
import json
import requests
# Joplin API configuration
JOPLIN_API_BASE_URL = "http://localhost:41184" # Ensure the Joplin API is accessible
JOPLIN_API_TOKEN = "your_token_api_joplin" # Replace with your Joplin API token
# Gnote notes directory
gnote_directory = os.path.expanduser("~/.local/share/gnote") # Default path for Gnote
# Function to create a notebook in Joplin
def create_joplin_notebook(title):
headers = {'Content-Type': 'application/json'}
data = {'title': title}
response = requests.post(f"{JOPLIN_API_BASE_URL}/folders?token={JOPLIN_API_TOKEN}", headers=headers, data=json.dumps(data))
if response.status_code == 200:
notebook_id = response.json()['id']
print(f"Notebook '{title}' created successfully. ID: {notebook_id}")
return notebook_id
else:
print(f"Error creating notebook '{title}': {response.text}")
return None
# Function to create a note in Joplin
def create_joplin_note(title, body, created_time, updated_time, notebook_id):
data = {
'title': title,
'body': body,
'parent_id': notebook_id,
'user_created_time': created_time,
'user_updated_time': updated_time,
response = requests.post(f"{JOPLIN_API_BASE_URL}/notes?token={JOPLIN_API_TOKEN}", headers=headers, data=json.dumps(data))
if response.status_code != 200:
print(f"Error creating note '{title}': {response.text}")
else:
print(f"Note '{title}' created successfully.")
# Function to clean specific Gnote tags
def remove_gnote_tags(text):
text = re.sub(r'<link:.*?>(.*?)</link:.*?>', r'\1', text) # Remove <link:...> tags
text = re.sub(r'<size:.*?>|</size:.*?>', '', text) # Remove <size:...> tags
text = re.sub(r'<[^>]+>', '', text) # Remove any other XML tags
return text
# Function to convert dates to timestamps
def convert_to_timestamp(date_str):
# Replace the comma with a dot for a compatible format
date_str = date_str.replace(',', '.')
try:
return int(datetime.datetime.strptime(date_str, "%Y-%m-%dT%H:%M:%S.%fZ").timestamp() * 1000)
except ValueError:
try:
return int(datetime.datetime.strptime(date_str, "%Y-%m-%dT%H:%M:%SZ").timestamp() * 1000)
except ValueError:
print(f"Unrecognized date format for date: {date_str}")
return None
# Main function to convert notes
def convert_notes():
# Create the notebook in Joplin
notebook_id = create_joplin_notebook("Gnote Imports")
if notebook_id:
for filename in os.listdir(gnote_directory):
if filename.endswith(".note"):
filepath = os.path.join(gnote_directory, filename)
with open(filepath, 'r') as file:
content = file.read()
# Extract title, body, and dates
title = re.search(r'<title>(.*?)</title>', content).group(1)
body = re.search(r'<note-content .*?>(.*?)</note-content>', content, re.DOTALL).group(1)
body = remove_gnote_tags(body) # Clean specific tags
created_time = re.search(r'<create-date>(.*?)</create-date>', content).group(1)
updated_time = re.search(r'<last-change-date>(.*?)</last-change-date>', content).group(1)
# Convert dates to timestamp
created_timestamp = convert_to_timestamp(created_time)
updated_timestamp = convert_to_timestamp(updated_time)
if created_timestamp and updated_timestamp:
# Create the note in Joplin
create_joplin_note(title, body, created_timestamp, updated_timestamp, notebook_id)
# Execute the note conversion
convert_notes()
