Change to Keyboard Shortcut Does Not Work
Version Joplin 2.9.17 (prod, win32)
I changed the keyboard shortcut for search in all notes from F6 to F3 and saved the change. I go back to the notes. F3 does not cause a search. F6 still does cause a search.
I tried other changes to the search in all notes function. None of them take effect.
Are you sure you made the change AND saved it in the key UI ?
