Backup plugin problem with portable Joplin
Joplin 3.2.12 (prod, win32)
ID client : 7af44f1d85a94a40b026600569e1bea5
Version de Synchro : 3
Version du profil : 47
Trousseau supporté : Non
Révision : d6f1ca4
Backup: 1.4.2
Copy link to active note: 1.0.1
EncDecModeV3: 3.0.1
Ez Table: 1.0.2
Freehand Drawing: 2.14.0
JSheets: 1.1.3
Table Formatter Plugin: 1.2.1
Text Colorize: 1.2.5
Joplin Cloud
Rich Text Editor
When using Tools/ create backup, I have the message "createZipArchive: spawn C:\Users\jb\AppData\Local\Temp\2s3Bv3Vqmle0h34XzEtDRo89wZF\resources\build\7zip\7za.exe ENOENT".
The file does not exist, so I copy "build" folder from my profile "resources" folder to Appdata specified location and rerun portable Joplin -> same error.
Watching the appData specified location, I can see that Portable Joplin recreates "build" folder (and other files) into appdata. Then Joplin window displays those files disappear only app.asar remains.
Thanks for help.
Reverted to "normal" version.
