The same URL/login/password works fine on Joplin Linux desktop version.
Date,Level,Message
04-16T20:43:26,30,"""Reducer action", "DECRYPTION_WORKER_SET""
04-16T20:43:26,30,"""DecryptionWorker: completed decryption.""
04-16T20:43:26,30,"""DecryptionWorker: starting decryption...""
04-16T20:43:25,30,"""Reducer action", "FOLDER_UPDATE_ALL""
04-16T20:43:25,30,"""Updating all notifications...""
04-16T20:43:25,30,"""Garbage collecting alarms...""
04-16T20:43:25,30,"""Total resources: 3""
04-16T20:43:25,30,"""Reducer action", "SYNC_COMPLETED""
04-16T20:43:25,30,"""Total folders: 1""
04-16T20:43:25,30,"""Total notes: 4""
04-16T20:43:25,30,"""Operations completed: ""
04-16T20:43:25,10,"""TypeError: Network request failed
onerror@index.android.bundle:133:4815
value@index.android.bundle:118:1505
value@index.android.bundle:117:6656
value@index.android.bundle:117:3396
index.android.bundle:117:9584
value@index.android.bundle:46:1389
value@index.android.bundle:25:3449
index.android.bundle:25:960
value@index.android.bundle:25:2703
value@index.android.bundle:25:932
[native code]""
04-16T20:42:34,30,"""Reducer action", "NAV_GO, Log""
04-16T20:42:27,30,"""Reducer action", "NAV_BACK""
04-16T20:42:23,30,"""Reducer action", "NAV_GO, Status""
04-16T20:41:46,30,"""Settings have been saved.""
04-16T20:41:46,30,"""Saving settings...""
04-16T20:41:46,30,"""Reducer action", "SETTING_UPDATE_ONE""
04-16T20:40:39,30,"""Reducer action", "NAV_GO, Config""
04-16T20:40:20,30,"""ResourceService::deleteOrphanResources:", """
04-16T20:40:20,30,"""ResourceService::indexNoteResources: Completed""
04-16T20:40:19,30,"""ResourceService::indexNoteResources: Start""
04-16T20:40:00,30,"""SearchEngine: Updated FTS table in 79ms""
04-16T20:40:00,30,"""Reducer action", "NOTE_UPDATE_ALL""
04-16T20:39:59,30,"""Reducer action", "SYNC_STARTED""
04-16T20:39:59,30,"""Starting scheduled sync""
04-16T20:39:59,30,"""Preparing scheduled sync""
04-16T20:39:59,30,"""SearchEngine: Updating FTS table...""
04-16T20:39:56,30,"""Reducer action", "NAV_GO, Log""
04-16T20:39:50,30,"""Reducer action", "DECRYPTION_WORKER_SET""
04-16T20:39:50,30,"""DecryptionWorker: completed decryption.""
04-16T20:39:50,30,"""DecryptionWorker: starting decryption...""
04-16T20:39:50,30,"""Reducer action", "NOTE_UPDATE_ALL""
04-16T20:39:50,30,"""ResourceFetcher: Auto-added resources: 0""
04-16T20:39:49,30,"""Reducer action", "APP_STATE_SET""
04-16T20:39:49,30,"""Application initialized""
04-16T20:39:49,30,"""Scheduling sync operation...""
04-16T20:39:49,30,"""Reducer action", "NAV_GO, Notes""
04-16T20:39:49,30,"""Reducer action", "FOLDER_SET_COLLAPSED_ALL""
04-16T20:39:49,30,"""Reducer action", "MASTERKEY_UPDATE_ALL""
04-16T20:39:49,30,"""Reducer action", "TAG_UPDATE_ALL""
04-16T20:39:49,30,"""Reducer action", "FOLDER_UPDATE_ALL""
04-16T20:39:49,30,"""Reducer action", "MASTERKEY_REMOVE_NOT_LOADED""
04-16T20:39:49,30,"""Loaded master keys: 0""
04-16T20:39:49,30,"""Trying to load 0 master keys...""
04-16T20:39:49,30,"""Loading folders...""
04-16T20:39:49,30,"""Sync target: 5""
04-16T20:39:49,30,"""Reducer action", "SETTING_UPDATE_ALL""
04-16T20:39:49,30,"""Loading settings...""
04-16T20:39:49,30,"""Database is ready.""
04-16T20:39:49,30,"""Current database version", "18""
04-16T20:39:49,30,"""Checking for database schema update...""
04-16T20:39:49,30,"""Database was open successfully""
04-16T20:39:49,30,"""Starting application net.cozic.joplin-mobile (prod)""
04-16T20:39:49,30,"""====================================""
