[Android] callback links
Hi here,
I'm not really sure if it's a bug because I don't know if the feature exists. I often use callback links to open a Joplin note from another application. It works fine on the desktop with Windows and Linux. But it doesn't seem to work on Android. Is it possible?
The use case. I have a task management application in which I would like to mention a link to a Joplin note that gives more details about the task in question.
I believe it is only implemented for desktop currently.
Ok, thanks for reply @Daeraxa
