Adding ```math as Alternative Latex Block
i like to use MkDocs to create static sites from Markdown documentation.
When used with katex the syntax is:
```math
... latex code ...
Since it isn't very straightforward replacing '$$' with ```math and ``` per math block this would be a great feature for better compatibility with the katex-mkdocs implementation.
Is this hard to implement? Maybe someone could point me in the right direction..
Thanks in advance.
Matt
This won't be possible. math is already used for the mathjs plugin.
