"absolute" reference links to the same note are not working anymore
Joplin 3.2.12 (prod, win32)
Client-ID: 725a25cc1d854272a691aaac2baba0db
Sync-Version: 3
Profil-Version: 47
Revision: d6f1ca4
Backup: 1.4.2
Conflict Resolution: 1.2.3
Copy Anchor Link: 1.1.0
Delete unlinked resources: 1.0.0
Freehand Drawing: 2.14.0
LanguageTool integration: 0.1.0
Templates: 2.4.0
Rich Text Editor
having a note with references to a "own" header line (# end) like
[absolute reference-link#end](:/<own-note-id>#end)
isn't working anymore...
If the note-id is not the own one, it points to another note, it is working...
Only "relative" Links like
 [relative reference-link#end](#end)
are working within the note.
Is this different behavior (compared to earlier versions) a "new feature" or is it a bug?
Best regards
Ralf
Not working for couple of versions already.
I may advice on fix if someone will be interested as I believe I've fixed in on my local through code changes.
