YesYouKan - Kanban plugin for Joplin
This looks amazing, but I can't install it. I have the latest macOS version of Joplin installed (3.0.15) but YesYouKan has a minimum version of 3.1.8. I feel like I'm missing something really obvious...
If it says a minimum of v3.1.8 it would seem that the plugin has been developed for what is currently the pre-release / release candidate version of Joplin (v3.1.x). The pre-releases are available here on GitHub. At the time of writing the most recent pre-release is v3.1.20.
The v3.1.x version of Joplin is soon to become a full release (actually it is a bit overdue). When that happens the clients will then start notifying users that there is an update.
Thanks!
Edit: Well, that didn't go as well as I expected. I installed the plugin, re-launched Joplin, and the contents of my last open note (which is my primary to-do list...) was replaced with the kanban settings block.
When I clicked "Create Kanban Board" in Tools (created for the second time and in a different notebook), one of the notes was eaten. Is this the same for you?
I am currently testing that as long as I write the following syntax to generate Kanban, it seems that I will not encounter any problems.
kanban-settings
Do not remove this block
TURN OFF YesYouKan NOW!
… until @laurent says it is safe to go back in the water.
See also: YesYouKan in Joplin 3.1.20 nuked a non-kanban note, leaving behind YesYouKan stub inside
UPDATE: Laurent responded in that discussion. He has removed it from the repo for now, fixed it, but it will not be ready for us to use until the next release of Joplin.
Yes, very sorry about that. Eventually I ended up losing a note too to this bug - it seems to happen when the app is first opened, but that should definitely be fixed from the next release
  • Can you add an option as edit and delete for every card where can add recurrence time , end date, tags ?
  • Can you add the option of change color of the card depends of big proyect that belongs, or a priority ?
  • it will be great to have notes as card becouse the alarm can be enable. ( I suposse that it´s imposible to add alarm to a card if is not a note )
  • By the way the tab is not working in title i supose that its imposible to add by other way, isn´t it?
    I ask it to have the emojis of priority more clear and separate.
  • I see that with 3.1.20 the problem at first look has disapear, good practice for recover notes ( note - note properties - previus version and choose one that have all data )
  • Do you have plan to be active in mobile, i see now as incompatible and the other kanban proyect ( the discontinued one ) that previously was working on mobile now has error when trying to move from a colum to other an cards disappear.
In any case thanks for your work.
v1.0.7 is now out and should be much more stable, but note that it requires Joplin v3.2 (which is currently in pre-release). Several of the changes that were requested here and on the repo have also been implemented:
v1.0.7
  • Allow running the Kanban board as an alternative editor
  • Fixed logic of hidding/showing the panel while browsing notes
  • Fixed styling
  • Allow pressing the tab key on the mini-note editor
  • Support checkboxes in kanban board
I created a Kanban note and another ordinary note that was not Kanban. When I clicked on the Kanban note to open it in a new window, the new window still had the UI designed by Kanban (because there is an eye image in the upper right corner. It indicates that it can switch to Kanban's UI mode), but if my main Joplin switches to a note that is not Kanban, the sub-window will be forced to switch to Markdown editing mode, not Kanban mode, and the eye in the upper right corner The picture view will also disappear, and the sub-window will not restore the Kanban UI until I select any Kanban note in the main window.
Thanks for the report, I created this issue to track this:
Hi @laurent could be too hard add a button that could hide the main meanwhile the kanban is visible? like the button used by the Outline plugin?
I'm not familiar with the outline plugin, could you provide a screenshot of what you mean maybe?
Was it an intentional design decision to not have the card titles be rendered markdown? ie. The ability to create the title with a checkbox, and/or make it a link?
I didn't really think about it, I guess it could be added since there's already something in place to render the card body.
I love this plugin. All I ever wished for.
Thank you so much. The UI and its integration is very nice
Hi installing latest plugin version on latest Joplin version 3.2.13 for Apple Silicon Mac made the app freeze. Had not only to disable the plugin and restart to get back to normal, but delete the plugin as such.
This was the error message i got :
An error occured: Window unresponsive.
A pre-release version of YesYouKan is now available. Note that you will also need the pre-release of Joplin to make it work.
v1.0.12
  • Resolves #14: Add support for mobile
  • Resolves #17: Allow using notes as cards
  • Render Markdown card titles as HTML
  • Resolves #6: Add support for card colors and added option dialog for cards
  • Resolves #24: Add option to set color to stack
  • Resolves #22: Display tags associated with the cards
  • Resolves #25: Add support for stack dynamic width
  • Resolves #27: Allow drag and dropping a note on the board
  • Add setting "Card double-click action"
A new pre-release is available. Like the previous one this is only compatible with the latest app pre-release.
  • Fixes #26: Opening a card in note while body is being edited loses the changes
  • Improve rendering performance for large boards with many cards
  • Resolves #23: Add due date to cards
How do we get this plugin enabled on iOS? I'm not able to find it via the plugin search even on the latest beta.
v1.0.15 is now available!
For now I'm only making it available as a pre-release since it requires Joplin v3.3 and not all users have it yet.
Changelog
  • Fixes #31: Clicking Checkbox card with associated note crashes Kanban editor
  • Fixes #32: Fixed card title top margin
  • Resolves #33: Add support for filering by tag
  • Resolves #44: Allow duplicating cards
  • Made board comparison more reliable to avoid unnecessary save operations
  • Display the number of cards that have been filtered out
  • Resolves #39: Auto archive completed items
Download
