SSL Database Connection string
For anybody like me that needs a SSL connection to the database in this form:
"postgresql://joplin:passw@private-db-postgresql.db.ondigitalocean.com:25061/joplin_pool?sslmode=require"
          - name: APP_BASE_URL
            value: "https;//joplin.example.com"
          - name: APP_PORT
            value: "22300"
          - name: DB_CLIENT
            value: "pg"
          - name: POSTGRES_CONNECTION_STRING
            value: "postgresql://joplin:passw@private-db-postgresql.db.ondigitalocean.com:25061/joplin_pool?sslmode=require"
          - name: MAILER_ENABLED
            value: "0"
          - name: NODE_TLS_REJECT_UNAUTHORIZED
            value: "0"
to get the ssl connection work you need to set NODE_TLS_REJECT_UNAUTHORIZED: 0
This topic was automatically closed 730 days after the last reply. New replies are no longer allowed.
