Sort Markdown Lists (Alphabetically, checked/unchecked, ...)
Hey everyone, I want to propose another markdown extension!
I often have long lists in my notes. Be it checklists or unordered ones. So when I want to (un)tick or change an item it's getting really complicated to find the actual entry.
What I want is an option to sort markdown lists. It should be sortable by the alphabetical ordering (abcd...xyz) and also by the checked/unchecked status (all unchecked items go to the bottom of the list).
So just like the ToDo items can be sorted, I want the markdown list items to be sorted, too! This should be doable easy with JavaScript :slight_smile:
Thanks for reading and hit me up with questions.
Miss it too. Should switch to something like MS Word for this, cut-sort-paste a block of text all the time.
Joplin supports line sorting (which is the same as list sorting). Simply select a block and press Ctrl-Alt-s. This feature isn't documented yet, but hopefully in the future we'll expose it better to the UI.
That sounds really good! Is there any way to do this on mobile? Or even enable it to run automatically after each new line that is written in a note?
It's not available on mobile (and probably won't be for a very long time if ever).
It's not currently possible but should be possible to add as a plugin fairly soon.
Is it possible to sort in the Z-A order?
Not currently, it just does regular sort.
Thanks for this. Still relevant in 2025. Curiously, lower case letters sort after upper case. For example iCloud sorts below Kindle. I wonder if there's a way to make sort ignore case.
