[Mobile] yarn serve-web build fails due to import resolution error (Folder screen)
Hi everyone,
I’m M Hassaan Saleem, and I’ve been setting up the development environment packages/app-mobile on Windows 11. I ran into a module resolution error when trying to run the web version using yarn serve-web. Yesterday, this was working fine, but today it gives these errors (see logs).
MY ANALYSIS:
That error references root.js, which don't exist in the repo. I realized this is the transpiled in-memory artifact of root.tsx.
Any help would be appreciated. THANKS!
PS D:\Open Source\joplin\packages\app-mobile> yarn serve-web
*[webpack-dev-server] Project is running at:
[webpack-dev-server] Loopback: http://localhost:8088/, http://[::1]:8088/
[webpack-dev-server] On Your Network (IPv4): http://172.17.160.1:8088/
[webpack-dev-server] Content not from webpack is served from './web/public/' directory
asset serviceWorker.bundle.js 129 KiB [emitted] (name: serviceWorker)
runtime modules 24.2 KiB 8 modules
modules by path ./node_modules/ 71.9 KiB
modules by path ./node_modules/webpack-dev-server/client/ 55.6 KiB 8 modules
modules by path ./node_modules/webpack/hot/.js 3.45 KiB
./node_modules/webpack/hot/dev-server.js 1.37 KiB [built] [code generated]
./node_modules/webpack/hot/log.js 1.01 KiB [built] [code generated]
  • 2 modules
    modules by path ./node_modules/@babelbabel/runtime/helpers/*.js 915 bytes
    ./node_mod@babelles/@babel/runtime/helpers/interopRequireDefault.js 214 bytes [built] [code generated]
    ./nod@babel_modules/@babel/runtime/helpers/asyncToGenerator.js 701 bytes [built] [code generated]
    ./node_modules/events/events.js 9.23 KiB [built] [code generated]
    ./node_modules/ansi-html-community/index.js 2.67 KiB [built] [code generated]
    modules by path ./web/ 8.59 KiB
    ./web/serviceWorker.ts 8.57 KiB [built] [code generated]
    ./web/mocks/empty.js 19 bytes [built] [code generated]
    webpack 5.97.1 compiled successfully in 2115 ms
    assets by info 4.3 MiB [immutable]
    assets by path *.ttf 3.41 MiB
    asset 1fcc36272ea3e53d0031.ttf 1.25 MiB [emitted] [immutable] [from@react-native-vector-icons node_modules/@react-native-vector-icons/material-design-icons/fonts/MaterialDesignIcons.ttf] (auxiliary name: app)
  • 6 assets
    assets by path *.png 2.6 KiB
    asset 776172e3164fd63761b6.png 492 bytes [emitted] [immutable] [from: node_modules/react-native-dropdownalert/assets/error.png] (auxiliary name: app)
  • 5 assets
    asset 4df5e7af1d8a6b183755.wasm 917 KiB [e@sqlite.orgitted] [immutable] [from: node_modules/@sqlite.org/sqlite-wasm/sqlite-wasm/jswasm/sqlite3.wasm] (auxiliary name: app) (auxiliary id hint: vendors)
    assets by path *.js 25.5 MiB
    assets by chunk 1.14 MiB (id hint: vendors)
    asset vendors-node_modules_buffer_index_js-node_modules_md5_md5_js-node_modules_path-browserify_ind-4122c9.bundle.js 579 KiB [emitted] (id hint: vendors)
    asset vendors-node_modules_sqlite_org_sqlite-wasm_sqlite-wasm_jswasm_sqlite3-worker1-bundler-friendly_mjs.bundle.js 526 KiB [emitted] (id hint: vendors)
    asset vendors-node_modules_sqlite_org_sqlite-wasm_sqlite-wasm_jswasm_sqlite3-opfs-async-proxy_js.bundle.js 63 KiB [emitted] (id hint: vendors)
    asset app.bundle.js 24.2 MiB [emitted] (name: app)
    asset utils_fs-driver_fs-driver-rn_web_worker_ts-utils_node_modules_moment_locale_sync_recursive_.bundle.js 116 KiB [emitted]
    runtime modules 104 KiB 46 modules
    modules by path ../ 11.3 MiB 2044 modules
    modules by path ./ 9.33 MiB (javascript) 4.3 MiB (asset) 1105 modules
    @aws-sdk/signature-v4-crt (ignored) 15 bytes [optional] [built] [code generated]
    util (ignored) 15 bytes [built] [code generated]
    fs (ignored) 15 bytes [optional] [built] [code generated]
    ERROR in ./root.js 1:3449-3490
    Module not found: Error: Can't resolve './components/screens/folder.js' in 'D:\Open Source\joplin\packages\app-mobile'
    using description file: D:\Open Source\joplin\packages\app-mobile\package.json (relative path: .)
    Field 'browser' doesn't contain a valid alias configuration
    using description file: D:\Open Source\joplin\packages\app-mobile\package.json (relative path: ./components/screens/folder.js)
    no extension
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js doesn't exist
    .web.js
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.web.js doesn't exist
    .js
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.js doesn't exist
    .web.ts
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.web.ts doesn't exist
    .ts
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.ts doesn't exist
    .web.mjs
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.web.mjs doesn't exist
    .mjs
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.mjs doesn't exist
    .web.tsx
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.web.tsx doesn't exist
    .tsx
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.tsx doesn't exist
    .web.jsx
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.web.jsx doesn't exist
    .jsx
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.jsx doesn't exist
    .wasm
    D:\Open Source\joplin\packages\app-mobile\components\screens\folder.js.wasm doesn't exist
    as directory
    @ ./index.web.ts 1:366-383
    webpack 5.97.1 compiled with 1 error in 9978 ms
Hi, I didn't build the mobile app, but according to Building the applications | Joplin you should avoid spaces in the project path.
Make sure the path to the project directory does not contain spaces or the build may fail.
Does re-running yarn tsc or yarn watch from packages/app-mobile help? yarn tsc and yarn watch are responsible for transpiling the .ts/.tsx files to .js files and folder.js was recently renamed and converted to TypeScript.
Thanks!
Thanks for help.
Can u plz guide that should we ask maintainer to first assign the issue and then work on that or just open the pr?
(I wasn’t able to find this in guidelines).
Yes, please. We usually don't assign issues, except to maintainers.
