Hello everybody, I would like to know if there is a way to "lock" changes to the text of the notes in rendered mode. I tried to do this via CSS code using the "userchrome.css" file but didn't get any results.
Thank you very much!
You can't edit the text on the rendered view.
Are you sure you aren't swapping to the rich text editor instead?
Top left is to swap between edit and rendered (and dual pane). The bottom one is to move to the rich text editor.
Thanks for the quick response Daeraxa.
Yes you are right, I haven't used Joplin for a long time, so I probably confused the Rich Text Editor with the Rendered.
