Joplin desktop does not synch in Linux Mint
Joplin 3.0.14 (prod, linux)
Client ID: b0e94464c4354463a085e19b2ca05429
Keychain Supported: No
Revision: 05cf51e
Backup: 1.4.1
Nextcloud
LM 21.3 Cinnamon, Edge update
In my older version of Joplin synchronization worked flawlessly.
Got the message that my Joplin version is too old to synch.
I installed an update via the recommended terminal command:
wget -O - https://raw.githubusercontent.com/laurent22/joplin/master/Joplin_install_and_update.sh | bash
Now I have v. 3.0.14
After installation all looks fine; old data to be seen. However, Joplin does not synch. Neither up to the NextCloud server nor down.
Synchronization settings
Synchronization target: NextCloud
WedDAV URL : path to my NextCloud followed by /remote.php/dav/files/name/JoplinSynch where "name" is my NextCloud loggin name, " JoplinSynch" is the folder containg the Joplin data
Check synchronization configuration gives following message:
Error. Please check that URL, username, password, etc. are correct and that the sync target is accessible. The reported error was:
path to my NextCloud followed by /remote.php/dav/files/name/JoplinSynch/ failed, reason: (Code ETIMEDOUT)
I re-entered all information several time using for name and password copy&paste => same error message
I can enter my NextCloud via web browser and the NextCloud add-on to Nemo file manager works fine.
What is the problem?
What did I do wrong?
What do I need to check?
What do I need to change?
Thanks in advance for helpful replies.
Log file
log.txt (6.67 KB)
Thank you for reporting this!
A fix for a similar (possibly the same) timeout issue should be in the 3.1.3 pre-release. It should also be included in a 3.0.x release in the near future.
Note: If you decide to upgrade to the v3.1.3 pre-release, be sure to create a backup of your data first!
Thanks for your explanation!
I understand that I have to wait for the next release of 3.0.x.
How is this announced?
Where can I get this improved version?
Can the same Linux command be used to install this update?
How long could this take?
3.1.3 Pre-release
What means latest-linux.yml? I don't understand "yml"
How can I make a backup to my data?
How can I install the pre-release in Linux Mint (based on Ubuntu)?
I installed 3.0.15 and synchronization does not work. Error message remains the same.
Am I the only one who has this problem? I did not find any post reporting the same problem?
Is pre-release 3.1.3 really the solution?
Thanks in advance for helping comments.
I installed now pre-release 3.1.4. Again the same situation as described at the beginning of the thread.
I appreciate a lot helping comments to find the real issue and countermeasure.
As neither v 3.0.15, nor 3.1.4 synchronizes, I consider to uninstall Joplin completely and make a new installation.
Questions:
1 How do I need to uninstall Joplin in Linux Mint?
2 Which version would have the better chance to run properly - 3.0.15 or 3.1.4?
