Hi I'm using Joplin 2.11.11 on Linux. I converted a bunch of notes from a different application to fit the JEX file format, but when I try to import the JEX file, I get the error "Item cannot be null". It doesn't contain any information about what exactly caused the error. I enabled debugging in the flags file yet no information about the import attempt is logged. The only information that gets logged at all during this operation is
11:27:57: CommandService::execute: hideModalMessage
after I close the error modal.
Also I did a grep through the archive for any explicit "null"s and did not find anything.
Is there some way to get more information about the error?
