In console, notes with a specific tag can be listed with joplin tag list <tag-name>.
However, is there any command to do the reverse, listing tags of a specific note, something like joplin tag tag_list <note-id>?
It鈥檚 better to add tag list in meta data panel, so users can toggle it with tm.
Thanks.
if you have developper skill, you can use the API and the method
GET /notes/:id/tags馃敆
Gets all the tags attached to this note.
I forgot a simple solution :
curl -XGET http://localhost:41184/notes/<note id>/tags/\?token=<the token found in the webclipper settings>
will give for example
curl -XGET http://localhost:41184/notes/623d6a98d41844f0b850a94e486f876a/tags\?token=10bc0121f7caae37cd41dd748f098ae1f542487b2e2c2cc4f241e8a5f44e8cce67fe250f6a702976ff473ed94153738af36948e11382ff718cc0fe94d3b96be3
[{"id":"dc52e95edba643e5831ddfd18e15502f","title":"ansible","created_time":1544690822690,"updated_time":1544690822690,"user_created_time":1544690822690,"user_updated_time":1544690822690,"encryption_cipher_text":"","encryption_applied":0,"type_":5}]
To get the note id ; from the desktop ; right click "copy markdown link" and paste it in the console
I guess it would be better if it was support by the CLI tool directly, and I鈥檓 surprised it鈥檚 not actually.
