How-to guide for Mermaid styling
Hi everyone, I'm fairly new here but I've been using Joplin for a while, particularly to produce Mermaid charts.
Whilst I'm no CSS expert I have been fairly successful in modifying styles within the Mermaid code itself (as opposed to userstyle.css) using classDef as a container for styles.
If you wish to learn more - or indeed add to it as I'm very much still learning - I've written a short guide on the following link:
Great looking Mermaid flowcharts in seconds
Do let me know what you think. Thanks,
Dom
I just realised some may not be able to access this.
Below is a 'friend link' that enables you to bypass any paywall:
Great article. Thanks for sharing!
Nice!
But for some styling AFAIK we need to use CSS.
For example, if I want to change an arrow's color I can't change also the harrowead color.
Next I 'll show what I mean.
If I have a simple graph like this:
graph RL
    A:::someclass --> B
    classDef someclass fill:#f96;
    linkStyle default fill:none,stroke-width:3px,stroke:red
I obtain this.
0001
If I want to make also the arrowhead in red I need to mess with the CSS.
First, I need to find the ID of the arrow.
I done this by looking into teh note with the "HELP -> toggle developers tools" but now I know it is simple.
It is actually very simple; the ID is "L-" then there is the id of the first node, a dash and then the of the second node.
Then, I do in my note:
   ```mermaid
      graph RL
          A:::someclass --> B
          C --> D
    <style>
    #L-C-D .arrowheadPath {
         fill:red !important;
    </style>
and I obtain:
0002
With style you can do a lot of trikcs. It's quite simple and better documentated than mermaid.
If anyone knows a better or simpler way I'd like to know it.
Do you know how to style classDiagram in mermaid in Joplin?
I'm not sure i did understand what you mean, but if you want to learn what are the CSS class in the diagram you can do, as I did, opening the developers tools.
