Hi All,
I'm developing a plugin and would like to add custom JS to render content. Could you guide me to example or documentation where I can find it.
Thanks!
Hi All,
Thanks!
thanks, I've checked it. However, the question is still open - when it runs?
I need to apply JS on a particular DOM element after I got the note updated - can you help me with that please?
I believe it runs whenever a note is rendered. Is that what you need?
AFAIK there is no native event for it.
I do work around by inserting style element and use it's onload to fire up JS code.
<style onload="alert('test')"/>
It launches as soon as tag gets into DOM.
So for example you could insert style tag and have its onload wait for DOM element with intervals.
