macOS
Joplin 3.1.24 (prod, darwin)
Client ID: 43b598a428a6402eb15fbd0711d16028
Revision: d581264
Backup: 1.4.2
Dropbox
Rich Text Editor
Remove color feature does not work. It works for new text but if you color a phrase, paragraph etc. and select all that text and choose remove color then it does nothing, I have to manually go to markdown and find the right codes to remove.
