I honestly don't see why
div.editor-toolbar div button {
display: none !important;
Wouldn't target that button in markdown mode, you can see in the html that button is a child of a div which is a child of div.editor-toolbar.
oh well
Thanks for your help, much appreciated
I will just have to live with it then cause if you cant see why its not working, there is little hope I will be able too
Honestly baffled, this is what I expect to see:
If you want to try one final thing you can check if it works in the dev env.
Go Help > Copy dev mode command to clipboard
then paste that in either a terminal or whatever thing openbox might have like dmenu. It will open a new Joplin instance unrelated to your main one with its own profile in .config/joplindev-deskop
which will have no notes, no plugins, no nothing.
If it doesn't work there then I think your Joplin install is haunted.
If I want to clean install which folders do I also have to delete (tried uninstalling and reinstalling but all my configs were the same (dark, sync etc)
Is it just the Joplin, Joplin-desktop, and now joplindev-desktop folders in ~/.config?
You have got me invested enough that I'm putting openbox onto that AL vm...
Basically yes, Joplin is the cache but holds no config data, joplin-desktop and joplindev-desktop are your config folders, removing those should "reset" everything fully.
Success!
I uninstalled, deleted my configs, and reinstalled and the first thing I did was to cut and paste from your post above into my new userchrome.css
I was very careful as my system currently opens the css file from the Joplin menu in LibreOffice Writer
Although I always save as text, I just shut LO straight after it was opened by the Joplin menu - thus generating the css file, and then edified the css in xed
Now to get back to where I was with sync and dark and a keybind I changed (indent)
All appearance, pluggins (just 'Menu items, Shortcuts Toolbar icons' and 'Simple Backup'), markup, keyboard shortcuts and webclipper done and still no button
Fully synced and exactly how I like it
Toggle Editor Button still not there
Its solved
No idea why it happened
Maybe installing and uninstalling plugins?
Just guessing
Anyways, a clean install was required
Thanks for help and apologies for hijacking thread
Well that was an adventure, I'm still puzzled how it could have happened in the first place unless it was something weird in the PKGBUILD.
ENHANCEMENT REQUEST: Make hiding the WYSIWYG toggle a simple toggle option in the config menus.
I had no issue hiding it with CSS (I believe I had to restart Joplin though). My biggest issue was finding the CSS snippet that enabled this. Note, I can also understand the position that Laurent may not want the ability to hide that button such an easy thing to do, but ... yeah, I do. Stick it in the advanced settings section. Side note: I think most non-default settings need to be moved into an "advanced" set of sections since the config menus are getting ... a bit too crazy.
Anyway. @laurent, that's my request. Thanks! -todd
