Help with CSS for li?
Edit: Figured it out; answer at the bottom.
Original post:
I'm hoping someone can help me with this. I would like my checklist items to be closer together, vertically. I was able to accomplish this with CSS for checklist items that have the same level of indentation, but not for nested checklist items:
I don't really know what CSS to write, if it's possible, to affect the nested checklist items. The pointer in the Development Tools box is not finding much for me, and I am not a web developer, so I don't have much of a clue.
The CSS that worked for same-level checklist items was:
li {
  margin-bottom: 0em;
The only thing I knew to try for the nested items was (which didn't work):
ul {
  margin-bottom: 0em;
Any guidance is much appreciated!
Edit: Okay, I figured it out with the help of the Development Tools pointer and somebody's CSS they had done on unordered lists in the "Share your CSS" thread.
I guess checkbox lists are ordered (?); not sure. I applied CSS to both list types and that fixed the issue:
ol, ul {
  margin-top: 0em;
  margin-bottom: 0em;
I still have to play with the look a bit, but overall, it's solved. :slight_smile:
Great to have an answer added.
Could well help others.
Keith
