Using Windows version: Do you think it would be technically possible in this type of web interface to implement a feature that allows users to navigate through a list of notebooks or notes by typing the first letter of an item? For example, typing "W" to directly focus on the notebook named "Work"?
Thanks!
The ARIA Authoring Practices Guide suggests including similar functionality:
- Type-ahead is recommended for all trees, especially for trees with more than 7 root nodes:
- Type a character: focus moves to the next node with a name that starts with the typed character.
- Type multiple characters in rapid succession: focus moves to the next node with a name that starts with the string of characters typed.
— Tree View Pattern | APG | WAI | W3C
(Note: Related post: Accessibility/desktop: Expand/collapse notebooks and sub-notebooks without root focus)
Until this is implemented, it should be possible to jump to a notebook using the Go to Anything dialog (opens with ctrl-p on Windows/Linux). From the Go to Anything help text (emphasis added),
Type a note title or part of its content to jump to it. Or type # followed by a tag name, or @ followed by a notebook name. Or type : to search for commands.
Thank you for the consistently precise information. I hadn't delved deeply enough into the ARIA Practice Guide. I wasn't aware of the Ctrl-P shortcut yet; it's indeed convenient and another plus for Joplin!
