Joplin 3.1.20 (prod, linux)
Client-ID: 6a17e1c064524fe79622fcdf7070a050
Sync-Version: 3
Profil-Version: 47
Unterstützter Schlüsselbund: Nein
Revision: 8199362
Backup: 1.4.2
Conflict Resolution: 1.2.3
History Panel: 1.0.2
Note overview: 1.7.1
Note Tabs: 1.4.0
Nextcloud
With version 3.1.x my css in userchrome for inline code no more working.
I've changed it to the following to style inline code and list items.
.ͼ17 .cm-inlineCode {
	color: #7bbb61;
	border-width: 0;
/*------ Editor: list elements ------------------------*/
.ͼ1a {
	color: #c2a674;
It works as expected, except when inline code appears in a list item. Then the list item style override the inline code style.
I am happy if someone can help me to define the styles.
Thanx everyone working on Joplin!
@jExplorer1 welcome to the forum.
According to other posts on this and the CodeMirror forum you should not use any css classes beginning with ͼ.
Thanx for your explanation! I think I understand this in principle.
But I'm not so familiar with css. What can I do to adress the right css class in this snipped, for example to get rid of the border for inline code:
<span class="ͼ1a"> List item and </span>
<span class="cm-inlineCode" spellcheck="false" autocorrect="false"><span class="ͼ1a tok-meta">`</span><span class="ͼ1a">inline code</span><span class="ͼ1a tok-meta">`</span>
The correspodending Joplin (or CodeMirror?) style is:
    border-width: 1px;
    border-style: solid;
    border-color: rgba(200, 200, 200, 0.5);
    border-radius: 4px;
    font-family: monospace;
Only, when I also take the class ͼ17 to the cm-inlineCode the border-width: 0; will work in my userchrome.css:
	color: #7bbb61;
	border-width: 0;
Thanx for advise.
I believe that you may just need to add !important to the setting to get rid of the border.
.cm-inlineCode {
	color: #7bbb61;
	border-width: 0px !important;
I have not found a way of applying formatting to lists.
Changing the style of code blocks in list items
I originally posted a reply for how to style inline code that appears in a list item differently from inline code that is not in a list item (I misunderstood the question). I've included this description (minimized) below:
Applying different styles to inline code that only appears in a list item
Styling just inline code in list items
I've just opened a pull request that should make this possible without using internal CodeMirror CSS classes.
Until then, does the following work?
/* List items are 1) not headers and 2) have a <span class="tok-meta"></span> as a first child. */
.cm-line:not(.cm-header):has(:first-child.tok-meta) .cm-inlineCode {
  /* Inline code in list item styles here */
Edit: For hiding the inline code border, see @dpoulton's suggestion above.
Styling list items
/* List items are:
 1) not headers (:not(.cm-header))
 2) not table delimters (:not(.cm-tableDelimiter))
 3) and have a <span class="tok-meta"></span> as a first child. (:has(:first-child.tok-meta))
Note: This also applies to non-list paragraphs that start with bold or italic text.
.cm-line:not(.cm-header):not(.cm-tableDelimiter):has(> :first-child.tok-meta) {
  /* List item styles here */
  color: #c2a674;
In the future, list item styling may be simplified by this pull request.
Edit summary: 1) Hid original solution 2) Linked to above answer for hiding inline-code border. 3) Added "styling list items" section. 4) Added note: CSS applies to non-list items.
The !important does the trick, thank you!
Hi, nice to see your work on this!
But in my test, all inline codes now are formatted red, whether in a list item or not
  	color: red;
Maybe, I've misunderstood something?
Isn't that what you wanted - for the inline code colour to be the same in the note body and in lists?
(From Original post 🡇)
Ahhrg, sorry my fault. It's OK so!
