When double clicking on a codeblock, an internal editor opens, if i select all and try to paste i always get the ``` ``` in the paste. Is there a way to copy paste the clear text without the markup annotations?
I think that there's a plugin that adds a copy button.
Thank you , i installed the plugin and it seems to work if i use keyboard shortcut control c control v on LINUX, if i right click to copy, the menu doesnt show, i will stick with that for now ![]()
thanks!
