Note: I might be wrong about some of the rules below. If so, please correct me!
Summary
Code feedback has included suggestions not caught by eslint. The goal of this document is to collect a list of common stylistic issues that are not auto-detected/fixed by eslint.
Rules
Use TypeScript for new files
Creating a new .ts file
Because the TypeScript compiler generates .js files, be sure to add these new .js files to .eslintignore and .gitignore.
To do this,
- If the TypeScript compiler has already generated a
.jsfile for the new.tsfile, delete it. - Run
yarn run updateIgnoredin the root directory of the project (oryarn run postinstall)
Filenames
camelCase.ts: Files that export multiple things.- Example:
checkForUpdates.ts
- Example:
PascalCase.ts: Only if the file contains a single class, which is the default export.types.tsorfooTypes.ts: Shared type definitions- Example :
types.ts
- Example :
Use camelCase for constants in new code
Bad:
// Bad! Don't use in new code!
const GRAVITY_ACCEL = 9.8;
Good:
const gravityAccel = 9.8;
Indent using tabs
VSCode: In
vscode, be sure to check whether new files are created withtaborspaceindentation! Spaces can be converted to tabs using the command palette.
Avoid ==
Use === to check equality. This keeps our code style consistent across TypeScript and JavaScript files and avoids a misleading compiler error message.
See also
Declare variables just before their usage
What about numeric constants? E.g.
const gravityAcceleration = 9.8; // m/s
BAD:
// Bad!
let foo, bar;
const doThings = () => {
// do things unrelated to foo, bar
// Do things involving foo and bar
foo = Math.random();
bar = foo + Math.random() / 100;
foo += Math.sin(bar + Math.tan(foo));
Good:
let foo = Math.random();
let bar = foo + Math.random() / 100;
Prefer const to let (where possible)
Prefer () => {} to function() { ... }
Prefer arrow functions to function() { ... } in new code.
// Bad!
function foo() {
Good:
const foo = () => {
React
Use react custom hooks to simplify long code
If eslint gives an error about useFoo being called outside of a component, be sure the custom hook is titled appropriately.
See also
Other projects' style guides
We aren't using these guides, but they may still be helpful!
- TypeScript Deep Dive ā Style Guide
- Google TypeScript style guide
- See also
ts.dev's style guide, which is based on the Google style guide.
- See also
- Javascript standardstyle
- Possibly useful for adding to
.eslintrc.js: listseslintconfiguration flags for each of their suggestions
