I cannot build the cliclient
Can someone please help me in the same, I have no problem in building the desktop or mobile application
ERROR log
0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli 'C:\\Program Files\\nodejs\\node.exe',
1 verbose cli 'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
1 verbose cli 'start'
1 verbose cli ]
2 info using npm@6.13.4
3 info using node@v12.16.1
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info lifecycle joplin@1.0.161~prestart: joplin@1.0.161
6 info lifecycle joplin@1.0.161~start: joplin@1.0.161
7 verbose lifecycle joplin@1.0.161~start: unsafe-perm in lifecycle true
8 verbose lifecycle joplin@1.0.161~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;C:\Users\risha\Desktop\joplin\CliClient\node_modules\.bin;C:\Users\risha\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\local\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\usr\bin;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\risha\bin;C:\Python27;C:\Python27\Scripts;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Program Files\nodejs;C:\ProgramData\chocolatey\bin;C:\Program Files\Microsoft VS Code\bin;C:\Program Files\Java\jdk1.8.0_211\bin;C:\Users\risha\AppData\Local\Microsoft\WindowsApps;C:\Users\risha\AppData\Roaming\npm;C:\Program Files\Git\usr\bin\vendor_perl;C:\Program Files\Git\usr\bin\core_perl
9 verbose lifecycle joplin@1.0.161~start: CWD: C:\Users\risha\Desktop\joplin\CliClient
10 silly lifecycle joplin@1.0.161~start: Args: [
10 silly lifecycle '/d /s /c',
10 silly lifecycle "gulp build -L && node 'build/main.js' --profile ~/Temp/TestNotes2 --stack-trace-enabled --log-level debug --env dev"
10 silly lifecycle ]
11 silly lifecycle joplin@1.0.161~start: Returned: code: 1 signal: null
12 info lifecycle joplin@1.0.161~start: Failed to exec start script
13 verbose stack Error: joplin@1.0.161 start: `gulp build -L && node 'build/main.js' --profile ~/Temp/TestNotes2 --stack-trace-enabled --log-level debug --env dev`
13 verbose stack Exit status 1
13 verbose stack at EventEmitter.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:311:20)
13 verbose stack at ChildProcess.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:311:20)
13 verbose stack at maybeClose (internal/child_process.js:1021:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
14 verbose pkgid joplin@1.0.161
15 verbose cwd C:\Users\risha\Desktop\joplin\CliClient
16 verbose Windows_NT 10.0.18363
17 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "start"
18 verbose node v12.16.1
19 verbose npm v6.13.4
20 error code ELIFECYCLE
21 error errno 1
22 error joplin@1.0.161 start: `gulp build -L && node 'build/main.js' --profile ~/Temp/TestNotes2 --stack-trace-enabled --log-level debug --env dev`
22 error Exit status 1
23 error Failed at the joplin@1.0.161 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
