Advice on plugin API to use for custom rendering
Hi
I plan to work on a plugin that will render markdown from TODO.md format as a Kanban board.
Can you please advice if there's already an API I could use to "replace" the default renderer?
Thank you
For custom Markdown rendering, you can create a content script:
See also here for more info: https://joplinapp.org/api/references/plugin_api/enums/contentscripttype.html#MarkdownItPlugin
Thank you!
