Adding Header and Footer possibility for PDF export
Is it possible to add a header and footer to a note, which then appears on the exported PDF?
I also tried already the CSS code in this post here.
The situation:
I added the following CSS code to a note:
<div>
  <img src=":/ac38ca0d13b947a69cf61fe35bcd3271">
</div>
The banner does also appear, but around it, I have a big margin. I can work around this with the following CSS code, but this has some unwanted quirks:
@page {
  margin: 0%;
But then everything has no margin like text or also tables.
I want to have a header file, respectively a picture at top and then like normal my text, tables whatever. Is there any possibility to achieve this?
Or can I call to a possible feature request to implement such feature, of course only if it's really possible.
I wanted to have exported pdf have footer, like this: {pageNo} / {totalPages}
Can you please help with this?
