Yes You Kan Questions
Dropbox
The Yes You Kan plugin description states that you can activate an auto archive option for tasks that are done. I have turned this option on but I don't see my done tasks being archived. I set it to archive after 1 day, and it's been 3 days now.
Any thoughts on why this is?
Additional Information: I have a few kanban boards. Some of the done tasks are either just cards, cards turned into notes, or cards turned into to-dos. Some of these notes/to-dos have been moved into a different sub notebook called "Kanban tasks." I don't like how the notes/to-dos populate my kanbans notebook, hence why I moved some of them. I left some in my kanban notebook because I didn't know if moving the notes/to-dos would mess up the auto-archive funtionality.
Which version of YesYouKan? There was some bugs related to archiving cards, but that should be fixed in the latest version
disregard this comment
I just updated to the latest one. let me check this out for two days and see if the auto-archive works.
i’m assuming the cards that are marked as done before the update won’t be auto-archived correctly? only the new cards i mark done will be auto archived?
Disregard @laurent it seems to be working now. Thank you sir.
