Joplin 1.3.11
Windows 10 20H2 19042.610
WYSIWYG editor
Tables:
When I delete columns from a table it looks fine in the WYSIWYG editor however when I switch to Viewer the previous, deleted columns are visible. The edit isn't saved.
Thanks for the report. It seems all table-related commands didn't trigger a save operation, but that will be fixed in the next release. In the meantime, you can for example add space and delete it to trigger a save.
