t0dd
8 September 2026 12:27
1
3.7.16
Tested with Light and Dark theme. Same behavior.
See screenshots.
If you publish a note, the title in the note list changes color. If you select that note, the item in the note list is highlighted, but it looks like any other note that has been selected. You can't tell that it is also a published note.
I've opened an issue on GitHub:
opened 12:18AM - 10 Sep 26 UTC
bug
### Operating system
### Joplin version
3.7.16
### Desktop version inf… o
Joplin 3.7.16 (dev, linux)
Device: linux, unknown
Client ID: 22dcd185199d4271afd19f331d3ed359
Profile Version: 53
Alternative instance ID: -
Sync target: Joplin Server
Editor: Markdown
Revision: 71f7872ac4 (pr/all/enable-joplin-server-new-auth-system)
Backup: 1.5.1
Freehand Drawing: 4.3.0
### Current behaviour
To reproduce:
1. Publish a note
2. Select a different note
3. Observe that the published note has special styling in the notes list
4. Select the published note
5. Observe that the published note no longer has special styling
Screen recording:
https://github.com/user-attachments/assets/958d8f75-9b12-4e3e-861c-68f5577104e0
### Expected behaviour
As in Joplin 3.6,
- selected published notes should have a published indicator
- the published indicator should have an accessible contrast level with the note list background.
### Logs
_No response_
