TAG filter and Headers
Joplin Cloud
Hello, and thank you in advance for all the support.
I would like to know if there is a way to filter TAGS directly from the sidebar. I’m aware that filtering with #tag works, but I’m wondering if there is any built‑in method to filter them from the sidebar itself.
I’m also curious why Markdown headings — level 2 (##) and level 3 (###) — appear almost identical in formatting. It’s quite difficult to distinguish them at a glance. Is there any workaround or solution for this?
Best regards, and thank you very much.
