Sync timeout issue
macOS
Joplin Cloud
Rich Text Editor
I’m hoping someone can help. I’ve been using Joplin for years with no problem. I have tried for 2 days to troubleshoot myself but I haven't solved the problem. I wondered if it was because I wasn’t emptying the bin and there had been many multiple note files stocking up and eventually I was getting very slow sync and other issues. After trying multiple things I took all my Joplin apps offline except my main Mac. I set the maximum connections to 1 and set the note history to disabled. I then re-synced from my Mac to Joplin Cloud. After multiple syncs (the first very slow of course) I have never had a normally completed sync - it always says Gateway error 504. Please see the attached log. Can someone tell me what is wrong? I have attached the sync log.
Thanks in advance.
Joplin 3.4.12 (prod, darwin)
Device: darwin, Apple M3
Client ID: aef3571f788a427096f9f2fc8b72dba1
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
Log file
-1758261081361.log (106 KB)
Hard to say. There are quite a few threads with the same error. Some were caused by error on server side, others were resolved by optimizing Joplin.
i think i’ve optimised everything i can. What would you suggest is the next step?
You’ll have to wait for Joplin developers/maintainers to give you proper answer.
As a workaround, you could try setting up sync to OneDrive or DropBox.
Don’t forget to backup your notes.
Thanks I will. In the meantime - the next sync suggests a server-side error: Logger.ts:317 18:27:05: Synchronizer: Details: GET api/items/root:/:/delta: Error 500 Internal Server Error:
nginx/1.18.0 (Ubuntu) (500): 500 Internal Server Error
I can’t find the official Joplin Cloud status page, but according to Joplin Status there have been outages today
@piggle Are you still having issues?
Yes - but have given up and moved to Onedrive. Thanks for your help
