as an example I try to sync 20 files. Sync begins and stops e.g. at 3/20. Nothing happens until I click on another folder or tag. Then it stops e.g. at 11/20. Sync doesn’t continue until I click on another folder or tag and so on. Synchronization is really fast, if I click on folders or tags randomly during the sync process, but I don’t assume that this behavior is intended. I’m using the Desktop Application on Linux and Nextcloud for syncing, encryption is enabled.
