Sync from Linux Client does not work anymore - error: put
Joplin 3.3.13 (prod, linux)
Device: linux, AMD Ryzen 5 7430U with Radeon Graphics
Client-ID: 6db0b06aad764718bcc1b0378588a25d
Sync-Version: 3
Profil-Version: 47
Unterstützter Schlüsselbund: Nein
Alternative instance ID: -
Revision: 144ed593c
Backup: 1.4.3
Freehand Drawing: 3.0.1
WebDAV
Remote-Elemente erstellt: 1.
Abgeschlossen: 19/08/2025 11:06 (30s)
Letzte Fehlermeldung: Error: PUT .resource/7871c4f0a72c4f93be298c233448e9d5: Unknown error 2 (507):
I am using mailbox.org as the webdav-server.
  • working connection status is in the report
  • space is should be enough
I am syncronizing from my Android phone and seams to work.
In the meanwhile I am helping me with transfering backups but it is not comfortable.
I do have a test-Joplin client within a VMware and this works does also not anymore (it worked for a while.
Log file
flags.txt (43 Bytes)
Hi all,
it works now.
Problem: the 30 days-free on mailbox.org account has acutally enough space. But maybe there are other limitations.
Solution: I have upgraded to a paid plan. After doing this, it worked out again.
Stefan
