Support for Encrypted Notes and Notebooks Proposal draft
GSoC 2026 Proposal Draft – Idea: Support for Encrypted Notes and Notebooks – Abhijit Sahoo
Links
1. Introduction
I am Abhijit Sahoo, a Computer Science undergraduate with strong experience in TypeScript, JavaScript, and React-based applications.
  • Background / Studies:
    Undergraduate student in Computer Science with focus on software development and systems.
  • Programming Experience:
    • TypeScript (production-level experience)
    • JavaScript, React
    • Familiar with Web Crypto API
    • Experience working with databases and application architecture
  • Open Source Experience:
    • Contributed to React-based open-source projects
    • Explored and studied Joplin codebase (EncryptionService, BaseModel, plugin API)
    • Set up Joplin locally and executed test suite successfully
2. Project Summary
Problem
Joplin currently supports end-to-end encryption (E2EE) at the sync level, but once unlocked, all notes are readable locally. There is no way to protect specific sensitive notes.
Solution
Introduce per-note and per-notebook password-based encryption, allowing users to lock sensitive data individually.
Why It Matters
  • Protects sensitive information (credentials, personal notes, medical data)
  • Adds fine-grained security
  • Useful for shared devices and local access threats
What Will Be Implemented
  • Password-protected note encryption
  • Notebook-level encryption with inheritance
  • Secure encryption using AES-256-GCM
  • Key derivation using PBKDF2 / Argon2id
  • UI for encrypting/unlocking notes
  • Resource (attachment) encryption
  • Session-based key caching
Expected Outcome
  • Fully functional encrypted notes system
  • Seamless integration with existing Joplin sync
  • Secure client-side decryption model
Out of Scope
  • Password recovery (intentionally impossible for security)
  • Full-text search inside encrypted notes (initial version)
3. Technical Approach
Architecture
  • UI Layer (React)
    • Encryption dialog
    • Unlock interface
    • Placeholder for locked notes
  • Service Layer
    • NoteEncryptionService (core logic)
  • Crypto Layer
    • Web Crypto API
    • AES-256-GCM encryption
    • PBKDF2 key derivation
  • Database Layer
    • SQLite schema updates
    • Metadata storage
Key Design Decisions
  • Encryption happens client-side only
  • Password is never stored
  • Use of verification token for fast password validation
Changes to Joplin Codebase
  • Add fields to:
    • notes table
    • folders table
  • Modify:
    • SearchEngine (exclude encrypted notes)
    • Resource handling
  • Add new service:
Technologies
  • TypeScript
  • React (Electron + React Native)
  • Web Crypto API
  • SQLite
Challenges
  • Secure key management without storage
  • Performance of PBKDF2 (~200–400ms)
  • Mobile crypto compatibility
  • Handling edge cases (export, duplication)
Testing Strategy
  • Unit Tests (Jest)
    • Encryption/decryption
    • Wrong password handling
  • Integration Tests
    • Database encryption flow
  • UI Tests
    • Encrypt → Lock → Unlock flows
  • Manual Testing
    • Sync across devices
    • Mobile compatibility
    • Export behavior
Documentation Plan
  • User guide (how to encrypt/unlock notes)
  • Developer documentation (crypto design and architecture)
4. Implementation Plan
Week 1–2
  • Study Joplin codebase
  • Implement encryption utilities
  • Write unit tests
Week 3–4
  • Database migration
  • Core encryption service
Week 5–6
  • UI implementation
  • Integrate with service
Week 7
  • Resource encryption
Week 8
  • Search handling
  • Session management
Week 9–10
  • Password inheritance
Week 11
Week 12
  • Testing and documentation
Week 13
  • Buffer + final improvements
5. Deliverables
At the end of the project:
  • Encrypted notes and notebooks feature
  • Resource encryption support
  • Full UI implementation
  • Unit + integration tests
  • Documentation (user + developer)
  • Clean and reviewed pull request
6. Availability
  • Weekly Availability: Full-time during GSoC
  • Timezone: IST (UTC +5:30)
  • Other Commitments: None
