Joplin 3.7.21 (prod, linux)
Device: linux, 12th Gen Intel(R) Core(TM) i5-1245U
Client ID: c8232fb8cbed4f3c93fa6c9ca9472961
Profile Version: 54
Keychain Supported: No
Alternative instance ID: -
Sync target: OneDrive
Editor: Rich Text
Revision: e41516e
Backup: 1.5.1
Conflict Resolution: 1.2.3
Freehand Drawing: 4.3.0
Kminder Mindmap: 0.8.7
Note Tabs: 1.4.0
OneDrive
Rich Text Editor
I am using Joplin to keep notes for a French class I am taking. I have notes for verbs, for nouns, etc. When I learn a new one, I add it to the note. I have to manually keep the note sorted by copying out, sorting, and pasting back. Is there a way to do that inside of Joplin?
There is no built in sort for lines inside a note as far as I know. Two options that work for me.
1. Switch that note to the Markdown editor, keep one word per line, and use a plugin that sorts selected lines. Search "sort" in Tools > Options > Plugins, there are a couple that add a Sort lines command.
2. Split it into one note per word (or per letter) in a notebook. Then the note list sorts itself by title and you never have to touch it.
For vocab I ended up with option 2, it also makes search nicer.
I like option 1. I have a lot of entries, though they are not a word, more lines like this:
bricoler - tinker/D.I.Y
I don't see a plugin that will sort lines in a standard note, however. I think Shopping list might work - I'll try that first, unless you have a better recommendation.
If you temporarily switch to the markdown editor, there is a built in option in the menu, to sort a selection of lines: Edit > Sort selected lines
Ok, I switched to markdown mode, selected some lines, and opened the Edit menu. I see sort selected lines, but it was greyed out. I toggled the editor layout and eventually it was no longer greyed out. It worked great! Thanks!
The only issue I have, which is one I have in other apps, it that I wish I could get it to sort french. It puts all the words with accent marks at the end instead.
