Android
I have a couple of memos that are showing up on the Windows PC app but not on Android. Windows PC app version is 2.13.15. Android phone is Galaxy S20+. I restarted the S20+ but this did not resolve. Should I uninstall and reinstall the Android app? Any other steps to troubleshoot recommended?
At least to start somewhere I would ...
  • create a backup of your Joplin profile on windows
  • re-upload everything (using the switch in advanced settings )
  • check logs on win to see it all worked out
  • erase the Android app, reinstall it, and sync again.
Whatever this brings about, it might help to point you in the right direction.
