Separate Folders for Profiles and Notes
Setting
I am using Windows with two different users.
I want to place the notes storage to a public users folder
to be able to easily share note between the two windows users.
Current Situation
Joblin uses a sub folder of the users home that is currently executing joblin.exe
for storing profiles and notes/notebooks.
Accessing this folder from an other windows user is extremely inkonvenient or nearly impossible.
Suggestion
Keep the folder for profiles and the storage for notes/notebooks separated in the options thus making it possible to keep profiles private and notes shareable in different folders in the file system.
Configuration
Operating System
Attribute Wert
Edition Windows 10 Pro
Version 22H2
Betriebssystembuild 19045.6466
Prozessor Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz, 3.20 GHz
Installierter RAM 16,0 GB (15,9 GB verwendbar)
Speicher 477 GB SSD MT-512, 466 GB WDC WD5000AADS-00M2B0, 8 GB SSD Msft Virtual Disk, 932 GB HDD TOSHIBA DT01ACA100
Grafikkarte Intel(R) HD Graphics (32 MB)
Produkt-ID 00331-20350-00000-AA892
Systemtyp 64-Bit-Betriebssystem, x64-basierter Prozessor
Joplin 3.5.12 (prod, win32)
*Attribute Wert
Sync-Version 3
Profil-Version 49
Unterstützter Schlüsselbund Ja
Alternative Instanz ID -
Revision 449555c
Backup 1.5.1
Freehand Drawing 4.2.0
