Selection issue (RTE) - BUG?
Rich Text Editor
When selecting multiples lines in order to checkbox them only the first is checkboxed:
Same thing with numbered list tool:
and bulleted llist tool:
I can reproduce this issue with the Rich Text Editor on Fedora 41 Linux.
Do you want to open something on GitHub ?
If you found a bug it's much easier for us if you can post it directly on GitHub, instead of posting it here and then wait for us to create the issue.
Ah ok ! I didn't know that I can do that...
Thanks!
And yes creating the bug report on GitHub is the preferred way. That used to be mentioned in the support ticket here, but it got lost when we switched to the support template.
