Saved or linked search
Android
Is there a was to save searches? If not then does Joplin allow creating deep links for search queries?
I find the plugin Embed Search simple and very useful for keeping often used searches. You can define your search in any note, (I have a :magnifying_glass_tilted_left: Search notebook and put all searches I want to keep in there).
You can define a search inline between other note content, or a note with just the search only. For example, you could have a note Recently Updated, and a search definition of "updated in the last seven days". There are many possibilities.
I'm not sure it this will address your need, but mention it in case.
Yes, although this hadn't been updated in some time, it works for my use case. Thanks.
