Resource management
On Windows 10 + Android. Syncing with Syncthing. No E2EE.
Is there no way to forcefully delete specific resource files?
What happens if I identify the images I want to delete and delete the files in the .resource folder?
I ask because I still have double resource files from the default notes from both desktop & Android.
Another thing, on Android the Note History setting is a slider, so if there is a discrepancy between desktop and Android note history setting, what happens?
What if the note history setting is turned off on Android?
Unrelated, but still want to put it out there, Joplin Webclipper, is there any way to have the Clip simplified page to add image urls from the site itself rather than downloading them? Is there an option? Am I missing it somehow?
