The inline code and the code block look differently on the desktop apps than they look on the mobile apps. Not really sure why that is, since the same css should be used on all apps (except cli).
Since a picture says more than a thousand words…
Desktop:
Mobile:
Inline code should indeed look the same, but code block in mobile is not color highlighted at the moment.
I know about the highlighting, but I actually meant the slight grey background for the code block.
/ref https://github.com/laurent22/joplin/issues/791
