Maybe, I didn't look at their format yet. But I was thinking about it the other day and it would be nice if the format was Markdown too, so you can open the file in a different app and see the structure. But I don't know if that's workable for such a feature as I guess the content can be quite complex
Looking pretty cool so far. Would be nice if zooming out could go a bit further (or ideally have infinite zoom) and having some means to undo promoting to a note, as it could easily be done by accident (an undo toast could be sufficient).
There's a couple of bugs I've found:
If you delete note for a promoted card, you end up with this:
When clicking the zoom in / zoom at button after it is fully zoomed, it highlights the Text button and you can't deselect it unless you select some text within a card. This doesn't happen when the fit view button is pressed, when it is disabled:
The undo stack seems to get reset when you deselect a card, as you cannot undo changes anymore if you re-select the last card (undo does work while the card is still selected)
I just tested the new canvas and it's really good, but I do have some feedback:
Being able to change the origin or destination of an edge by dragging it would be nice. Right now, I often need to delete an edge and reenter the label for the new edge when I only want to change where the edge comes from on a card.
Entering a label on an edge requires lots of mouse movement right now, maybe double clicking could immediately enable typing?
JSONCanvas supports color, which would be a nice addition
