I have my fork of Joplin set up to compile through AppVeyor and everything seemed like it was going dandy, no errors, but at the very end when it comes to making the artifacts, I get this error:
skipped publishing file=JoplinPortable.exe reason=release doesn't exist and not created because "publish" is not "always" and build is not on tag tag=v1.0.184 version=1.0.184
/ElectronClient/app/package.json
line 10 shows that publish is already set to ‘always’, so I figured maybe this was /appveyor.yml
's skip_non_tags: true
setting, so I figure out how to override it through AppVeyor’s UI by pointing it to a private gist and that seems to work, except that by the end, I just get the same error, so that didn’t solve my problem.
I’m out of ideas on where to go from here, would appreciate any help you could give me. I’m so damn close.
