Hello I had successfully installed Joplin on my companys Synology drive using an easy guide. Everything was working correctly. However port 443 needs to be aimed at a different device on the network.
What would be the best way to use a different port? I've tried searching for a solution myself, but I'm new to working with servers.
Okay that's perfectly doable. I try to explain it with this guide:
There in Step 12 you have to edit the APP_BASE_URL to https://joplin.mariushosting.synology.me:8443 (replaced with your Domain, the important part is the :8443).
And in Step 17 you have to choose the Reverse Proxy Source Port accordingly, as of my example to 8443.
If your company has a firewall, it probably has to forward the port to the Synology.
Then everything should work with port 8443: https://joplin.mariushosting.synology.me:8443
