Plugin: Turn to chart
The plugin is so great. I was wondering if the same idea behind it could be use to make a plugin for pie chart? I know that mermaid can be use to do it, but I prefer Turn to Chart aesthetic and it is adapting to my dark theme... and mermaid keep a white background.
Just asking in case.
Oh thanks @shbach , that's so powerful with the formulas. I've added a section in the readme of the plugin to mention it.
Great suggestion. It looks better I agree so I've made it the default behaviour on the v1.4.0. For anyone wanting the previous legend style, I've added 2 options: legendOrientation and legendTitle.
It should be possible yes. The custom options would be slightly different I imagine but the code will be really similar.
Hi, I haven't tried it out but it seems there is no way to make a radar (spider chart) with it. Am I right?
You're right. It's just bar chart and line chart.
I just noticed that the customLocale, that was working some time ago, is not working anymore? Is there some things I did wrong?
Hello @GabrielMPhi, thanks for raising it! It is a bug indeed. I've made some changes recently to use a more modern chart library under the hood (visx) and to able to convert csv as well but I introduced this format problem by mistake. Hopefully it should be fixed with version v1.9.3.
Hi @SamuelGagnepain, Great work on this plugin. I love it.
I've noticed that the lowest value in the table sets the horizontal starting point for the chart. Is there a way to set 0 as default point horizontally?
Answered my own question: yAxisOrigin: from zero
